n-stream and iradio podcasts in presets
Posted by: balma01 on 31 August 2012
If I wish to listen an iradio podcast with my UNITI I've to go in (for example) PODCAST BY LOCATION / EUROPE / ITALY / RADIO3 RAI / BATTITI) and I see a list of the last podcasts available and I can listen to one of it.
I can store one of it in my presets but unfortunately I cannot store the list of the most recent podcasts so if after some days I whish to listen to a new podcast using the preset, I have to select the preset, the system tries to go inside the podcast but it is old so the system cannot find it, I have to press STOP and the system goes in restoring history state, after a while the system says "no stations press play to reconnect" and pressing LIST I see the new podcasts listed and I can choose one of them.
What happens if I do not use IR remote but I use n-stream 3.0?
