Best subwoofer cable??
Posted by: ajay1223 on 02 September 2012
between supernait and rel r505
Posted on: 03 September 2012 by Richard Dane
Best check with REL here.  It will depend on whether you want to take signal at pre-level or high level.  If the former, then go for the Naim sub cable - it is specially slugged so the pre-amp can drive it without instability.  If the latter, REL can advise, although with Naim you need to take the high level reference signal off the loudspeaker terminals NOT the power amp terminals.
Posted on: 07 September 2012 by ajay1223
We ARE NOT using speaker level as it is to messy, is it possible to get RCA to RCA sub from naim as the only cable I can see is RCA to DIN?
