Reflections on CD Ripping
Posted by: mutterback on 06 September 2012
Currently at 400 of 2,000 (?). I'm ripping to FLAC on a VortexBox appliance using a mix of VortexBox auto ripper and dbPowerAmp.
1) I wish it burned calories
2) Prompts me to bring up the subject of a Computer Audio Wiki again
3) I found this really helpful, even if you don't use a VortexBox: http://info.vortexbox.org/tiki...ge=Rip+CD+Collection
4) dbPowerAmp is generally better - faster, more accurate -  than VortexBox auto rip, and using a ripper that lets you edit metadata as you rip is absolutely critical for Classical and Jazz. Haven't tried U Serve. MusicBrainz Picard tagger is nice, but, editing tags in bulk without the CD in front of you is tough. I couldn't find a Mac ripper that I really liked, and pulled out an old PC for the task.
5) for rock/pop, being able to set up the VortexBox near your CDs and just pop in the next CD toaster style is fantastic.
6) I re-discovered a lot of music I hadn't listened to in years. just banging through the ripping process gets unbearable after 50 CDs, you gotta use it as an excuse to listen
7) About 1 in 20 CDs is damaged and can't be ripped properly - though many can still play just fine.
8) Classical metadata is a pain to keep consistent. I liked this recommendation best: http://wiki.musicbrainz.org/ClassicalStyleGuide but I can't stick with it. They recommend a CD artist always be the composer. Hmm. For Glenn Gould's Goldberg Variations, I want Glenn Gould as the artist, not Bach. Will need to see what various player apps do with Composer tags.
9) Jewel cases suck. Arty innovations in CD packaging suck worse.
10) Trying to do other things while ripping CDs and being interrupted every 5 minutes drove me nuts. Though, as a method of procrastination its unrivaled - gives you a real sense of achievement and diligence while truly accomplishing nothing significant.
Posted on: 06 September 2012 by rich46
vital to clean every disk, to reduce errors i use a pledge fluffy dust that reduces any greasy marks quickly
Posted on: 06 September 2012 by Mike. G
I have a vortexbox too, how did you install an alternative ripper on the box? & how do you know its more accurate? I'm not sure what software it uses as standard.
I've been cleaning my CD's before ripping them using a very fine micro fiber cloth under hot water, then once dry, a bottle of ROR. I got fed up, after burning about 200 - 300 CD's six months ago, need to get back on it.
How have you got yours setup?
Posted on: 07 September 2012 by Pev
If cleaning doesn't work on hard to rip discs I find I can usually get a rip using a less demanding (than EAC) ripper. I use Windows Media Player (only use I've ever found for it). It's not bit perfect but the rips seem to sound ok. Also worth trying another drive - the drive in my cheap laptop rips discs that the expensive Blu-ray drive in my HTPC won't handle.
Posted on: 07 September 2012 by Forester
Mutterback, Interesting feedback.  I found that ripping non-classical CDs was a walk in the park compared to the classical ones.  I have tried by trial and error to find a way to label them that retains album artwork and allows me to find what I want using n-stream.  However it is a bit of a headache and then I looked at the link in your paragraph 8 - far too complicated for me. I am now using orchestra as artist but always ensure that composer, orchestra, chorus, conductor, main soloist, instrument and so on as necessary are labelled in the metadata.  Time consuming but hopefully the results will allow me to find the required music.  Compared to the other respondents I am not very houseproud as I never clean my CDs.  However the failure rate to date is about 3% for classssical ones and almost zero for non-classical.  Another issue I have faced is that sometimes the names used in assestnas are too long for the back up sysytem and then I have to go in and find and then edit them.  However I do not regret going down the streaming road.
Posted on: 07 September 2012 by mutterback
Hi everyone
Thanks for the notes on cleaning CDs. I probably haven't been as kind to my CDs as many here - college, then using them in the car really beat them up.
I'm using an old PC for dpPowerAmp - connected it via the home network to the VortexBox and set the rip destination there.
PS on db power amp being "more accurate." It checks the rip using a check sum against a database of other people's rips. If they don't match, it re-rips. Or, if a track isn't in the database, it rips 2x (or more) and compares the two passes.
It may not be more accurate ripper per se, but has built in quality control.
Posted on: 07 September 2012 by rich46
sometimes if you copy and then rip it again the problems you had go away.
i use a yamaha hd 1500 1500 rerip it then copy this for ripping
Posted on: 07 September 2012 by Geoff P
I use Asset UPnP which has a 'Folders & Filenames' search option so I have organised my music in folders and subfolders by Genre.
So for instance  POP is a folder which has two subfolders R&B and ROCK.
For classical I have 3 subfolders COMPOSER, ARTIST and COMPILATIONS. For my most dominant composers and for repeat peformances of their works in particular I use sub folders in the COMPOSER folder. For example BACH and then WTC with in there folders by the performing artist such as ANGELA HEWITT, MURRAY PERAHIA and so on. Where I have single performances by less obvious composers ( Scriabin for example) I use the performing artist name and file in individual folders in ARTIST making sure the details of the composer and work are in the individual folder title along with the artists name. If I acquire further single works by that artist that don't qualify for the Composer folder they get there own subfolder under the Artist's name in the Artist folder. COMPILATIONS is an obvious grab bag for multi composer/multi artist CDs.
It may sound complicated but If I forget where a performance is I can quickly check first the COMPOSER subfolders and if not there then move on and look in ARTIST whereI can be guided by artist name or composer. Doesn't take long to do that
Means a little refiling in my MUSIC folder after dB Poweramp has done its stuff but that not a big deal and works for me
Geoff
Posted on: 07 September 2012 by Bart
He "pulled out an old PC" for that.
Posted on: 07 September 2012 by JLD
For (very) striped cds, I've used an automotive polish an a microfiber and this gave surprising results...
(problematic tracks not re-ripped by dbpoweramp)
Hope this helps
Jean-Luc
Posted on: 07 September 2012 by Guido Fawkes
I don't think it is more accurate, it is just a bit more reassuring .... cdparanoia is a very accurate ripper ... XLD on a Mac uses it and adds accurate rip functions ... not known it get anything wrong so far ... there were a few of my CDs that were to difficult to rip.
Not sure about classical music as I've only ever ripped two ... seemed OK .. I put the composer as the album artist and the orchestra as the artist
But how do you know the Yamaha is an honest ripper?
I've got the earlier model, 1300, used to use without thinking twice ...
how do anyone know the naim is a good ripper or even a mac
Indeed
