Presets/favourites iRadio: how to set/edit?
Posted by: dickey on 08 September 2012
Hi,
In the past i have set some iRadio channels in the preset list. I think it is since the new n-stream update, but I cannot add another station to it or remove one from my current list. Does anybody know how to solve this? Thanks.
Regards, Dick
Posted on: 08 September 2012 by osprey
Originally Posted by dickey:
Hi,
Regards, Dick
Have you tried with remote controller (instead of n-Stream)?  That would narrow the problem i.e. is it down to the app or is there somehing wrong with the equipment.
Posted on: 08 September 2012 by dickey
I have just tried it, but it doesn't work (or i can't figure out how it works).
Have you followed the instructions given in the (NDX) manual (see extract below)? The note in the bottom is especially important.
5.5 Storing Radio Presets
When the handset store key is pressed the display will show a menu that enables confirmation of the preset store and options to rename or delete a stored preset.
Selecting the store option opens a menu that enables the preset to be stored in one of the forty locations. Scroll to the desired location and press the ok/list key.
Selecting Rename Preset opens a menu that provides the opportunity to rename a previously stored station. Scroll to the preset to be renamed and press the ok/list key to open a text entry screen. Use the handset numeric/text keys in text entry mode to select characters. Press the ok/list key to save the new preset name. See Section 3.7 for a full description of text entry.
Selecting Delete Preset opens a preset list menu. Scroll to the desired preset and press the ok/list key.
Note: Preset operations (store, rename or delete) are not possible directly from list mode. The store key must be pressed when in normal play mode to access these options.
Posted on: 10 September 2012 by dickey
Hi osprey,
With the remote control setting the presets works fine. Thanks for the tip. Now I know that it is just an app thing. Maybe it will be fixed with a next update. At least I assume that everybody has this issue.
Posted on: 10 September 2012 by osprey
Hi Dick, nice to hear that you managed to get the presets to work (even if only by using the remote).
