uniti software update
Posted by: Ellsworth on 23 September 2012
Apologies if this is a re-post. I did search first!
Im running software version 3.0 on my uniti. Im trying to go to 3.13 first and then the latest 3.16 as recommended. The BC SW is 10733. Ive bought the RS232 to usb 2.0 cable, set up the wired connections to router/uniti and pc. I'm running vista home. When i go through the set up process I get the message:
Unable to execute file C:\program files\naim\streamer update\UnitiUpgrader.exe
CreateProcess failed;code 740
The requested operation requires elevation
Tried rebooting etc. this is where my tech skills run out. any ideas??
thanks in advance...
