What software version
Posted by: kittybag on 23 September 2012
How do I find out what software version my Uniti 2 is running? It doesn't seem to appear anywhere on the device's webpage.
Posted on: 23 September 2012 by ChrisH
Hi Kittybag,
Press the spanner button on your remote, scroll to factory settings, select System Status, and you are looking for 'Version' which tells you your software version.
I forgot, you can also see it in nStream.
Press the Set Up button in the bottom right hand corner, and you find the software version in there under 'About'
Posted on: 23 September 2012 by kittybag
Thanks. Found it!
