Uniti updates via an iMac using xbmc problems
Posted by: Bigcol333 on 25 September 2012
I'm just getting sorted with my s/h Uniti, connected to my network, got xbmc which my uniti sees my iTunes library but won't play my wav files saying unsupported file format. So me thinks, maybe the update for my uniti will help. Bought the cable downloaded the update but it says needs a windows pc. I have a iMac. Is there an iMac version?
Ta
Posted on: 25 September 2012 by garyi
In short no.
i was not aware xbmc was transcoding, so before anything i would check xbmc. Have you eden installed? If yes try a nightly, if no upgrade to eden.
make sure in network settings of xbmc that upnp is turned on.
Posted on: 25 September 2012 by Bigcol333
Thanks. I will use a netbook pc with windows.Forgot I had that old machine! I've not heard of Eden. I think xbmc will work. All my music appears in the uniti window as the xbmc shothese the upnp server. Watch this space after the update otherwise tech support is my next step I think. I will look at Eden.
Eden is the current build of XBMC. When you first start it up it will say under the XBMC logo which version you are running, if it does not say eden, then download the latest version.
