Spotify and uniti
Posted by: steven2907 on 02 October 2012
Does it work
How do you set it up
Posted on: 02 October 2012 by AndyPat
Assuming you have already connected the Uniti to your network ( wireless) and have Spotify installed on a PC with a UPnP player (Asset is my choice) on it.
Select 'pc' on your remote.
Select the UPnP option.
Scroll to 'Advanced Search' and select it.
Scroll to 'PC Sound Capture' and select it.
Select 'Speaker(s) .........'
Start Spotify playing. After a buffer delay sound will come out of the speakers.
If you're connected by wire you may get other options pop up. Select accordingly.
A bit of trial and error may be required and you may have to access your sound card to adjust settings. My HP computer took a bit of fiddling. Sony Vaio a doddle.
Andy
Posted on: 04 October 2012 by Philippe Hebert
