Playing iTunes playlists with unitiqute
Posted by: Nils on 08 October 2012
Hi, assume this is quite basic - I am unable to play iTunes playlists from n-stream / iPad after the new version was installed...the playlist are presented ok, but the playback stops after the first song is finished...using iMac and playback upnp.
So what is the trick ?
Nils
Posted on: 08 November 2013 by trinity
Nils - I solved this by loading MusicFlow Application on my Ipad - to stream the music direct from my iPad - really happy with it. Now that I can play by iTunes play lists I am trying to find a really easy way to Automatically create new play lists using the High quality ripped music I have on my MyBook NAS drive.  - Any suggestions?
Posted on: 09 November 2013 by balma01
With musicflow is it possible to stream every ipad sound to the streamer? youtube for example?
Posted on: 11 November 2013 by trinity
Hi, yes I have streamed the audio track from you tube via music flow to my niam. Quality seems reasonable. For 3 US dollars it has been a good investment to extend the reach of what I can do with my investment in the Unitiqute.
