Ray Charles' recordings
Posted by: DanailT on 18 October 2012
Dear Gentlemen,
I would be grateful if you can point out some well executed recordings of Ray Charles' albums. Nowadays there are plenty of known and unknown labels issuing his work that I'm a bit confused.
Thanks in advance!
Cheers!
Danail
D,
Live in Newport is one of my favourites. Atlantic circa approx 1959. Genius + Soul = Jazz is also good.
Steve
This is an excellent sounding '62 mono vinyl.
Love his rendition of 'You don't know me'.
Rhino has put out a number of his records on vinyl and two very good cd sets, including one 5cd set of all the country and western music sessions. Which is a little misnamed as it includes CW sessions he did much much later than the one identified in Kuma's post! Excellent however. Most of the Atlantic stuff is worth a listen (not necessarily a purchase just a listen) but much of it very short which suggests they were cashing in on his ability to sell records at the time. Buy as you like!
this is what you want:
Rhino label
atb
kk
Thanks guys! Excellent suggestions.
Keano, this box-set is definitely quite interesting. I've checked amazon and apparently there is a re-issue of this as of 2012, which is minus the DVD for a lot less money. The thing that bothers me is that it says "remastered" for the new version, which is... hmmm not always a good thing.
Somebody with experience of the new Pure Genius CD box-set?
Cheers!
look out for the Steve Hoffman mastered work. You can find a list on his forum site.
atb
kk
Thank you guys fot the suggestions. I've received the Pure Genious CD box-set, now listening to the fourth CD - so far so good. I'm happy with it:-)
Waiting for the CD with Steve Hoffman remaster works. Will report later on it.
Cheers!
So how are you getting on? Planning on exploring more?
atb
kk
Most definitely yes:-)
I'm considering "Modern Sounds In Country And Western Music /Vol.1-2" and "Genius sings the blues"
I'm open to more suggestions...please.
Cheers!
D
box set 4cds modern sounds in country ray. got mine in usa . check it out
