Browsing iRadio with remote
Posted by: SamSam on 18 October 2012
Hi all
I have a question when using the remote with the uniti. The central pad allows mormally to go up or down on the list of iRadio preset stations (I mean the right and left buttons arooud the central button "ok/list"). But when a station is playing let say position 7, when I press the left button it goes directly to station 1 and wirh the right button it goes to the last station of the preset list.
I am using the last firmware but before the upgrade using  the right or left button will go  up or dowm by one station only. So it will be station 6 or 8.
Anyone experuences such behaviour? Is there a setup to make it work as before?
Thanks for your help
Posted on: 19 October 2012 by Peter_RN
Should you not be pressing the UP/Down to move one station at a time?
Posted on: 20 October 2012 by SamSam
Hi Peter Up and down button is for source selection. Regads. Sam
