Network cabling question -- RJ-45 coupler vs. switch
Posted by: Bart on 20 October 2012
Which would be the right solution for my application? This house was originally wired with one Cat5e run in the walls from my listening room to the laundry room, and another run in the walls from the laundry room to my "man cave room." Each is perhaps 60-75 feet, at most. I need to 'join up' the two cables in the laundry room so that I'll effectively have a connection from the man cave to the listening room. My NAS and UnitiServe can be in the man cave this way -- out of the listening room -- along with my cable modem/router and Time Capsule.
It seems I have two choices -- a simple RJ-45 coupler, or a gigabit ethernet switch. I'll also have a switch up in the man cave to connect the Time Capsule, NAS and uServe to my cable modem/router, so maybe that's a lot of switches (?) Is there any solid reason not to just use a coupler (or vice versa)?
TIA
