NDac & NDX
Posted by: Alanwong on 20 October 2012
Hi,
Currently I have nDac+XPS with my CDx2, I interested to play streaming audio.
i am wondering if I sale out the nDac and get the NDX? Or need to kept my nDac with NDX to get a better sound?
Please advice.
BR
Alan
Hi Alan -
I demoed an NDX with an eye towards replacing my DAC, and wound up keeping both.
I prefered the sound of the DAC's analog output, but fell in love with the NDX's ease-of-use and reliability. Also, the NDX's digital output sounded better than that of my PC's RME 9632 card in blind tests.
My current source is: NDX->DAC/555PS, and I am convinced it would take an NDS/555PS to better it.
Hopefully you can home demo before making any decision, as we all hear things differently. Good luck!
Hook
what does the rest of your system look like? (Amp, speakers?)
Thanks Hook!
Hi Shivoham, amp is 282/250 & speaker is Audio Physic Step 25.
at that level, do a home demo and go from there.
+1 DAC/555PS, to be honest so far in SQ it's pretty similar to NDS/555PS (pro and cons) with the NDS pulling away with the 555PS DR.
The DAC/555PS on the NDX is a superb combination that will keep you foot tapping for years to come.
Simon
No I don't believe so
Hi All
Do you use your power supplies on the NDX or NDAC or both for that matter?
A bit of apples vs. oranges Alan. Their functionality does not overlap. uServe is a server and a ripper and a storage device if you buy the HDD version, but can also function as a player for the DAC. The NDX is only a player; the rest of those functions I listed must be provided by other devices on your home network such as a computer to rip, and a NAS to serve.
Using the US price list - before taxes - as a basis for comparison :
1/ UnitiServe 2TB HDD & nDAC : $3695 + $3695 + $395 for the DC1 cable = $ 7785
2/ NDX & nDAC = $5195 + $3695 + $395 for the DC1 cable = $ 9285
With the latter combination, you will also need a NAS to serve files to the NDX, and your NDX will only be used as a streaming client ; the DAC section will be redundant.
I'm sure, as Hook and others have found, that the NDX network player into the nDAC is a wonderful combination, but you are paying an extra $1500 for a redundant DAC.
I've not compared the NDX+nDAC vs the UnitiServe+nDAC to be able to advise whether the musical reproduction abilities of the NDX+nDAC is worth the extra $1500. I can say however that the UnitiServe + nDAC is a truly wonderful and deeply musically satisfying combination.
Jan
Interesting! If you use the nDAC, then I guess NDX or ND5XS would only make a minor difference (since their internal DACs are idle anyway)? On the naim website, the nDAC is actually only mentioned as an upgrade to the ND5XS (though some obviously use it to upgrade the NDX, too). So perhaps ND5XS+DAC is a reasonable solution here?
Best,
Stefan
