nStream crashing
Posted by: happygiraffe on 20 October 2012
nStream on my iPad has beeh crashing quite often since the recent update to iOS 6.
Has anyone else had the same problem?
No probs with mine.....
Make sure that it's not crashing because generally you have too many apps running in the background over a long period of time.
Open up the "Fast App Switcher" (double-tap the Home button) and shut down what you're not using. Not doing this periodically can cause a lot of apps to crash. If you never do this, you can end up with lots of memory issues. Hard reboots do NOT remedy this -- you have to go in there and shut down apps. It's an under-discussed "feature" of iOS.
+1
... mine initially had a problem, but since a delete and reinstall, it has worked without problem.
Delete and reinstall?
my nstream also crash after ios6. I've tried delete & re-install, restore the iphone5, reset the ND5XS, reset router. It only open for few seconds then crash, I am mad.
I think the new version of n-stream 3.3 ONLY works if you have installed the 3.21 firmware update. I initially updated to 3.3 and it didn't work at all on my iPad or iPhone. I deleted 3.3 and managed to get 3.2 version back by syncing in iTunes.
I then did the firmware update to 3.21 on my unitiqute 2 and apprehensively updated n-stream to 3.3 and it works. Having said that the whole system seems a little flaky. Internet not working today all of a sudden and having to restart and reset whole system to get UPnP to work today...was all fine yesterday!
No, that's not the case, I'm running the new n-stream with 3.17 and it's fine.
Yes, been reading that on the forums, it's possible it's an issue with firmware version 3.20 which others seem to be finding too.
Hi, the known issue is specifically with streamer firmware 3.20 and it isn't a crash, it has difficulty switching inputs.
If you are seeing crashes would be helpful to know if you the crash relates to using a particular function, for example UPnP browsing or input switching. If you could send details to our support staff including the streamer version and iOS version you are using
Tom
