Iphone app crashing?
Posted by: Tony Lockhart on 08 November 2012
Is anyone else having this?
Tony
And some wonder why I don't stream music! I hate this sort of problem.
Tony
class="quotedText">
And yet using the web version of the forum, all is well.
Tony
Apart from having to constantly switch to the standard view because the mobile view is totally f@#king useless.
Willy.
I constantly have to re tap buttons on the ipad on this forum to open up anything.Strange as it does not happen with any other website, just this one.
Whoops there a Hoop in the Loop!!!
Peter, tried it with no success.
WhÅ· would using Chrome improve things if it does not occur on any other site with native ipad brouser? Suffice to say it does not work. .
Peter are you using the app or browsing to the site?
Tom, I do not use the app at all. In fact, I would avoid using using any app unless it is absolutely necessary.
Peter,
The problem lies with the app. All the browsers I've tried work fine.
Peter,
OK, so it is the app. However, maybe unrelated to the original topic, I very much prefer Chrome to Safari on all Mac machines - whether it is iMac, Macbook, iPhone or iPad. Personally, I think Safari is a daft browser.
Peter, Can I refer you to my post "tried it with no success"
Tony my apologies for being off topic, it really was to echo the problems there seems to be with the Naim forum, which does not apply to other sites.
The problems are random, but are still problems that need resolving.
Tom K and someone else said that the problem was with the app. Chrome and others are fine.
