How do I go 5.1 with an XS?
Posted by: JoexNaim on 28 November 2012
I have a nait xs gathering dust and a clapped out Arcam movie solo (which I need to replace)I also have a great Panasonic Blu-ray.
Any recommendations on a great 3 channel bolt on amp equipped with dolby, dts etc that would work well? Also, how does it all hook up, I see an AV bypass switch and warnings about 'full output'!
Or am I out of date and the markets moved on?
Posted on: 28 November 2012 by Simon Jenkins
Joe,
I just did something similar with my system. You need a receiver with pre-out connections for the front speakers, these go to one of the inputs on the XS which has unity gain, not sure what input that is as I use an 82. The receiver then powers the other channels.
One thing I noticed while looking for receivers, is it tends to be only the mid to high end receivers that have pre-outs. I ended up with a Pioneer SC-LX75, one down from the top of the range, but last years model, so I got it for 1/2 the price of the current SC-LX76, and the only changes between the two are the new one has 8 HDMI inputs rather than 7 (I have only 3 devices connected) and 4k up-scaling  but as 4k TV is several years from being remotely affordable this is not a problem as far as I am concerned. And it sound's great, especially on good DTS Master HD blu-rays.
As long as you don't need all the very newest bells and whistles, such as 4k up-scaling, then there are some relative bargains to be had by hunting out 1 generation behind receivers, as all the manufacturers seem to refresh at least once a year. I paid just over 1,000 euros for the Pioneer, the current model is around 2,000.
There are several good threads in the Home Theatre room on connecting everything up and configuring it.
Simon
Posted on: 29 November 2012 by JoexNaim
thanks Simon, googling the Pioneer as we speak!
