playlists, again, sorry...
Posted by: ken c on 05 December 2012
can someone cleverer and younger than me explain how i can create the sort of playlists i used to create with dtc where i would just highlight a whole bunch of albums and create a playlist from that. Looks like with nstream application on my iPad, i have to do this seequentialy, one by one, i.e., select an album, send it to a playlist, select next album, send to playlist, etc etc. very tedious, i am sure there is a faster way?
enjoy
ken
I think this is the way it has to be done, but it won't be that time consuming because there's a limit of 250 songs on a playlist - won't take you long to reach that an album at a time.
Gavin, many thanks. i thought perhaps i was missing some trick.
enjoy
ken
enjoy
ken
Wehey, you are back, where were you ?
ATB Peter
Not sure I'm cleverer or younger but as Gavin says, that's how it's done. I have also had the same thoughts as you though. Maybe in the future there will be improvements here. Lets hope so but it's not a real pain really. atb, Anton
thanks AntonD...
enjoy
ken
enjoy
ken
ATB Peter
been lurking... :-)
enjoy
ken
Not sure if I'm doing something wrong. I have just installed a ReadyNAS Duo and copied my iTunes albums to it. I can see and play the music....songs, albums, artists, but when I create a new playlist and go to the playlist listing on the App there is nothing there (it says empty). I was originally using Eyeconnect and this facility was working perfectly. Computer system is iMac. Any help/advice would be appreciated. Thank you.
don't know whether this is the same issue. i also dont 'see' my playlists where i expect to see them, uner CD collection. instead, i have to go to the 'play queue' and then 'Playists' (for those that i have created in n-stream) and then i'm able to see them. strange usability choice, but i have learnt to live with it now...
enjoy
ken
That works!
Thanks Ken
JG (new the streaming)
That works!
Thanks Ken
y're welcome John. All this streaming stuff is new to me too... but i have been very lucky so far. The change to make my Virgin SuperHub modem only and then attaching a DrayTek router was a big step fwd in getting rid of a lot of very annoying dropout problems.
enjoy
ken
