Good player for Mac mini
Posted by: Boj on 08 December 2012
Initially I went for itunes/bit perfect solution to find out my big collection of flac files are useless. Then after reading posts here and there I went for Fidelia/Fidelia Remote to find out I cannot set it to play the format original format, I.e. it resample and outputs the files to a presbit format. So I your advice on a good player, which is compatible with iTunes library, has ipad remote application, plays flac and automatically outputs bit exact. Many thanks for your recommendations.
