HI-Def WAV
Posted by: The Strat (Fender) on 25 December 2012
Guys,
I'm in completely foreign territory here so excuse me not using the Search facility but don't know where to start!!!
But simple question if I get a hi-def 24bit download in WAV can I play it in iTunes and on my POD?
Thanks,
Lindsay
Posted on: 25 December 2012 by PinkHamster
No, Apple is limited to 48kHz/16bit.
Posted on: 25 December 2012 by McGhie
But you can convert it to a lower number of bits/hertz and play it on an iPod
Posted on: 25 December 2012 by Aleg
Or you can download the GoldenEar app and play true high resolution.
Posted on: 28 December 2012 by Alan Paterson
Does Golden Ear allow the iPod to play it or iTunes to recognise it at the higher rate?
Posted on: 28 December 2012 by Aleg
GoldenEar plays the music itself, it also has its own library so its not integrated with iTunes.
but the sound quality is good.
aleg
Posted on: 28 December 2012 by PinkHamster
How does one load the desired flac files onto the iPod if they are not recognized by itunes?
GoldenEar can run its own ftp server, so with any ftp program you can send files to its library.
Also from within iTunes on a PC/Mac you can upload files to the iPxd from the Apps-tab of your connected device. There is a file sharing section on the tab where you can do that for Apps that have local storage. http://support.apple.com/kb/ht4094
But I find FTP route the easiest way to upload music files.
Aleg
Cheers!
Posted on: 28 December 2012 by Allram61
Hi,,, is there any pluginprograms for iTunes that i can use on my Macbook Air? And if so,,, would it do anything performancewise for listening via headphones??
//cheers magnus
