ND5XS - chassis or floating
Posted by: Thorsten_L on 01 January 2013
Hi!
Happy new year to all!!!
I came across this here in the manual of my ND5XS:
The NDX/5XS is fitted on its rear panel with a Signal Ground
switch offering two positions: Chassis and Floating. Select
the Chassis position unless NDX/5XS is connected in a hi-fi
system incorporating another earthed source component,
or mains “hum” is audible through the loudspeakers.
Contact your retailer, distributor or Naim for advice if
necessary.
Note: “Connected” in the context above means an
analogue audio signal cable that includes an earth
connection.
Now, I have a turntable via the Superline (earthed to the Superline) going as an analogue signal into my Supernait.
So according to the description I should put the switch on my ND5XS to "FLOATING", right?
Since already a source component ( = TT) into the Supernait is "earthed"...
Thank you in advance.
Posted on: 01 January 2013 by rich46
floating  try both it wont harm.  technical with most, floating avoids parallel earths.  I couldn't tell any difference
Posted on: 01 January 2013 by Thorsten_L
Thanks, rich.
Hmmm...me neither...leave on FLOATING for a while,
