Just received my ND5 XS. ... couple of questions?
Posted by: Salvo on 02 January 2013
Hi all and happy New Year!
Just received my streamer and set it up in my chain. As i do with the rest of my other kits i keep the utin on all the time, but I have noticed that it gets quite worm as opposed to the other pieces. I was wandering why this should be so. Also, can anyone tell me how I can check which firmware vesion I have installed?
Thank you and
Besr Regards,
salvo
Posted on: 02 January 2013 by Rich27
Are you connecting via wired ethernet or wireless?  I found when I had an NDX, that connecting it wirelessly caused the unit to heat up noticeably, perfectly normal I think.
Posted on: 02 January 2013 by Salvo
Hi, As a matter of fact yes it is conncted via WIFI. That makes it clearer, thanks. Salvo
Posted on: 02 January 2013 by PinkHamster
If this is so by design, then I would return it. They cannot possible advise to keep their units powered up and at the same time waste energy to such a considerable degree.
Also, neither my notebook, nor my iPod, nor my iPad, nor my Squeezebox radio heat up; and they are all running on constant wifi operation.
Posted on: 02 January 2013 by rich46
had one for a year     ,slightly warm .powered up 24 hours.       the unit runs on milliamps it should be hot
Posted on: 02 January 2013 by Iver van de Zand
Mine is connected wired, it is permanently on and isn't warm at all. I agree to have it checked by the dealer
iver
Posted on: 02 January 2013 by Jasonf
Hi Salvo,
Mine is on all the time and connected via wifi to the n-serve, it is currently hardly warm. However, when I first got it it run quite warm for a while, so perhaps it is normal in the beginning???? Maybe you should leave it a week or two before rushing back to your dealer.
Cheers.
Guys,
thank you all for your advice. I will keep the unit on for a week and see what happens.
I do hope is normal though (although I do not like it wery much)
salvo
SHOULD READ NOT HOT
