Naim Streamer Technology:
Posted by: Russ on 02 January 2013
Something in AMA's thread on the NDS DAC (specifically wondering whether the streamer and suspension of the NDS was enough to justify the higher price over the DAC) got me back to a point I have been wondering about for awhile--which is kinda-sorta related, but not enough to justify hijacking that thread:
To put it in a nutshell, we all know that source is extremely important--as is the DAC. So is the Preamp. Power--yes, but not so much. But how important is the streamer circuitry to sound quality?
I have been speculating to myself for some time how, with the Superuniti, if I ever did want to upgrade to separates, how the SU would perform just as a streamer--if one were to add pre, power, and DAC--together with perhaps a couple of power supplies, connectors, and/or Powerlines.
On the plus side, if you sold it, you would not realize enough cash to buy a separate streamer and then you would also be paying for a redundant DAC similar to the one you were silencing in the SU.
Another plus is that the power supply in the SU would be totally committed to the streamer--not that that means ALL the supply would go for that purpose--but just that it would not have to be doing anything else.
Finally, if any of your other components ever went belly up, you could revert to the SU as your primary system while waiting for the broken part, along with a year's salary, to get to the repair facility and back.
On the down side, you could say that it is an awful waste of circuitry--and it is true. Still, it would be cheaper than any of the alternatives.
So where does the streamer circuitry fall in terms of imact on sound quality?
How important are the quality of power supplies to the streamer performance--viz a viz their importance to preamps, source etc.
And finally, would the streamer functionality benefit as much from a clean power source/Powerline as do the other components?
Best regards,
Russ
