True UPNP streaming from a Mac? What software are you using to stream from your Mac?
Posted by: mutterback on 14 January 2013
I've been experimenting with various streaming programs from my MacBook Pro. The biggest issue I have is that the ones I've tested (Audirvana, Decibel) rely on a separate iTunes Library rather than truly browsing and streaming from a UPNP server directly. Pure Music seems to work the same way.
I'd like to avoid using iTunes directly given the problem of multiple iTunes libraries and the need to convert everything from FLAC to ALAC. I'm using VortexBox, which can automatically make a copy of the FLAC to ALAC, but still would like to avoid redundancy and all that extra storage space.
Any ideas?
