HiRes play back buffering issues
Posted by: Mort2k on 20 January 2013
Hi
Hoping someone can shed some light on this little issue.
If my ND5 has been on for a while (stays on at all times) and I select a hires track (24/96 or 24/192) it start to play and then the buffer drops to 0% and you get a pause, once it rebuffers you get a bit more then rinse and repeat! When this happens standard res play without issue.
Now for the strange bit, a reboot of the ND5 resolves the issue! I can listen ok to anything in that listening session. Come back the next day and we are back to the above.
Any ideas?
System
ND5XS/82/hi/250
Assett UPnP running on windows7
All music in FLAC
ND5 connected via CAT5 via 1gb switch
Rob
Any ideas?
System
ND5XS/82/hi/250
All music in FLAC
Rob
