Have you had this issue with your Synology NAS?
Posted by: Madrid on 21 January 2013
I am curious as to whether any one has had - and perhaps solved - a problem I have with my Synology 212J NAS...
My ND5 plays some, but not all, of my high res recordings that are streamed via hardwired ethernet cable from my Synology 212J and Netgear 8-port switch. On those tracks that do not play, all appears to be normal (eg, track plays according to n-stream, buffer constantly at 100%), yet no sound.
A (partial) solution is to disable FLAC to WAV transcoding on the Synology DiskStation setup. If I disable it, all high res tracks magically play. Is there a way to maintain the purported benefits of WAV whilst listening to all high res tracks?
