n-stream random play function
Posted by: Poggy on 31 January 2013
After having played with nstream for a bit now, is there a way to play all tracks on the server in random order without having to set up a playlist?
TVM
Posted on: 31 January 2013 by Jan-Erik Nordoen
It requires a long press. (excerpt below copied from here)
> Shuffle all function
I think we already offer this or am I missing the point? At any point in the browse tree long press the row and select play. Turn on the shuffle button and it will play randomly. This changes if you are using the app with a product that supports play queue - a long press then play will fill the play queue rather than just playing endlessly
