AV2/Unitilite Connection
Posted by: Charles Paterson on 13 February 2013
Hi, I'm on the verge of adding a Unitilite & was hoping for a bit of advice on the best connection & what cable should I get.
Any advice will be welcome.
Thanks, Charlie
Posted on: 14 February 2013 by rackkit
Hi Charles.
Copied and pasted from the FAQ - Accessories packed with Naim Equipment:
"AV2 - 180 DIN5-DIN5 Interconnect (yellow Band – 2way), AV/DVD remote, mains lead"
The 180 DIN5-DIN5 should be with your AV2 and is the cable that goes into the AV input of most Naim Pre amps that support the Unity Gain feature. I don't know the specs on the UnitiLite, so you would have to check that it has it.
Rack.
Posted on: 14 February 2013 by Charles Paterson
Many thanks for the reply.
Looking at the manual it only has Phono inputs so it would have to be a DIN to Phono, It's whether you can buy one ready made or would it have to be made on order.
Thanks, Charlie
Posted on: 17 February 2013 by rackkit
Thanks, Charlie
Have a search for a company called Flashback cables and see what the owner, Dave can come up with or suggest. He's a specialist in replacement Naim type cables. Many on here including me, have had various cables made up and the prices are more than reasonable.
Rack
Posted on: 17 February 2013 by Charles Paterson
Many thanks, I found the right cable there.
Cheers, Charlie
Posted on: 19 February 2013 by rackkit
Cheers, Charlie
Nice one Charlie, happy to help out.
Rack.
