Hi-res audo cover art
Posted by: antmast on 16 February 2013
Sometimes when you download a hires audio file and its cover-art in a music share, the cover art does not show in the IPAD Naim app, even after using the desk top client to load it. How do you fix this?
Posted on: 16 February 2013 by Bart
What are you using to play the files?  A Naim streamer/player (ND5XS, NDX, or NDS)?  And what are you serving them from (a UnitiServe?  nas running a UPnP server?).  If so, make sure that the cover art file is named "folder.jpg" and is in the same folder as the music.  That always works for me.
Posted on: 16 February 2013 by antmast
Nope, this works most of the time but not always. I am using a UnitServe SSD, the one without the harddrive.
Be sure to clear the cache, or uninstall and reinstall the iPad app, after fixing the files.  And do a re-scan with the UnitiServe.  It WILL always work, but after changes you have to do a re-scan and possibly force a cache clear on the iPad (or iPhone or OS X app).
Posted on: 17 February 2013 by antmast
I wonder if things are alright here. I used the desktop Client to delete the cover art db and then I did a db Rebuild. The UnitServe has been rebuilding for almost 12 hours. I have about 1300 cds.
Posted on: 17 February 2013 by Cbr600
Don't panic, I have 3500 files nd my DB rebuild usually takes around 1.5 - 2 days.
Posted on: 17 February 2013 by Harry
It may take another 12 hours, possibly more. The world record here is a week for three shares containing about 1000 albums. I think this was too long and something must have happened but it all came out perfectly when finished.
Posted on: 18 February 2013 by antmast
HOLY COW!!!  It's still going! This thing must be playing every file.
Posted on: 19 February 2013 by antmast
This is too much. Does somebody know the support number in Texas?
Posted on: 19 February 2013 by Bart
Texas is the home of the US distributor, The Sound Organization.  You can find them online
I've never done a database rebuild on my uServe (fortunately, I guess!).
Posted on: 19 February 2013 by Hook
You might want to contact Naim support directly at:  support@naimaudio.com
Good luck.
Hook
Well. It looks like my UnitServe's  internet contact needed re-establishing. The US distributor figured this out. Patience is a virtue but I might have waited a long time for that front light to stop blinking.
