Naim Desktop Client. What is the newest version?
Posted by: Dwamish on 19 February 2013
If I look at the HDX website I can find version 1.6 b desktop version. Is this the latest version? If not were can I find the latest one? My dealer said there should be an 2.011 version?
Anyone knows the answer?
Dwamish
Posted on: 19 February 2013 by Jonn
It's 1.6d. Go to the Naim site,customer support,updates to download.
Posted on: 19 February 2013 by Cbr600
My HDX is running the following
N serve version 2.4
HDX version 1.6d
Desk top client version 2.0.11.1165
Posted on: 19 February 2013 by Dwamish
Thanks! So I should download "version 1.6d update & desktop client- English 1.6D" by creating a cd-rom that I insert in the Unitiserve drive? Does this update also update the desktop client on the PC or is that not necessary? Dwamish
Posted on: 20 February 2013 by Claus-Thoegersen
The update from 1.6B to 1.6D was minor, and no update to the Dtc was necessary, so unless you have a problem wait for a major upgrade of the firmware.
Claus
Posted on: 20 February 2013 by Cbr600
what versions are you currently running?
Posted on: 20 February 2013 by Dwamish
I am travelling will check this weekend. Thanks Dwamish
Posted on: 20 February 2013 by Bruce Woodhouse
Anyone know if it runs on Windows 8? I just ordered a laptop that will run this.
Bruce
