"Celebration Day" vinyl - what's up?
Posted by: Kevin-W on 20 February 2013
Just tried to order the above via a well-known online retailer, and encountered this...
ITEM UNDER REVIEW
This product is not currently offered by Amazon.co.uk because a customer recently told us that the item he or she received was not as described.
We are working to resolve this as quickly as possible. In the meantime, you may still find this product available from other sellers on this page.
Anyone know what the problem is? Anything to do with the product itself?
Warped pressings according to the Steve Hoffman forum.
keith
keith
Oh thanks - looks like it may not be worth buying from anywhere else then.
I buy most of LPs from my local independent record store. It makes returning poor or scratched vinyl much easier. Not many left though :-(
Rough Trade East have got some in stock, I will pop over there and check before I buy. A bit more expensive but probably worth the savings in hassle.
Perhaps we should applaud Amazon for this? Warped and off-centre records are all too common and the supply chain doesn't need to do DNA tests to spot them.
Keith
Ordered mine lanight for from Spin CDs. It was dispatched this morning. Thanks for the heads up.
is this a widespread problem or a few rogue copies ?
Not sure Ian. Based on the widespread reports of warped and off center pressings elsewhere i suspect widespread.
Best of luck. I am sure more were done properly than not.
My copy is beautifully flat, well centered and snap, crackle and pop free...nicely packaged - they did not put the vinyl into the jackets, kept it in the inner sleeves out of the jackets.
http://www.rollingstone.com/music/n...-hed-be-open-to-led-zeppelin-reunion-20130218
No no no......leave the legacy alone. G
Received mine yesterday all 3 disc's have a very slight warp on one side.This doesn't effect the playing so will keep them.
Sound wise a lot better then the CD
Actually Ian I think it was Steve C.
Apologies to both Steves !
No worries Ian.
How flat are your replacements?
Wait to you get to Kashmir it sound awesome
