Windows 8
Posted by: Dwamish on 27 February 2013
Does Windows 8 work together with the Naim products?
Posted on: 27 February 2013 by PinkHamster
In which way?
Operating systems do not 'work together' with audio devices.
Posted on: 27 February 2013 by Dwamish
Sorry, I am a beginner and I have some issues connecting the DTC on my Windows Vista machine to the SU and US. So I wondered if Windows 8 would work with the DTC. The DTC will not connect to the US and I can not find out why.
Dwamish
I have been suggested that it is a firewall issue causing the problem to connect. So I was thinking of trying with another PC so I thought I would Up-grade to a Windows 8 operating system
Posted on: 27 February 2013 by Pev
Windows 8 is unlikely to help your problem unless the new install fortuitously changes the settings that are giving you problems. DTC works fine with Vista if it is configured properly. Try adjusting the firewall settings on your Vista machine.
Now I have to admit my illiteracy: What is DTC?
Posted on: 27 February 2013 by GerryMcg
The Desk Top Client .
Of course ... ![]()
Posted on: 08 March 2013 by Dwamish
Problem solved through My daughters boyfriend... It was a firewall issue after all. Thanks Dwamish
