Problem with NDX, Synology NAS and n-Stream settings (UPnP mode)
Posted by: martingo on 03 March 2013
I have NDX, which is streaming my music from Synology NAS 1512+. All my music is ripped as flac files. I also have some hi res 24/96 and 24/192 albums. The NAS is settled not to transcoce Flac to WAV ( disabled transcoding in the settings of the Media Server). I use n-Stream to control my NDX. The issue which I have is with the UPnP compatibility mode in the settings of the n-Stream. When it is enabled, all my files are playes as they should be => n-Stream show them as flac ( normal and hi res files are shown with the correct resolution). But the problem is that in this mode I can't use the playlist and queue support ( they are just not avilable in the n-Stream). If I disable the UPnP compatibility mode them I can use the full functionality of the n-Stream with queue and playlist but I have an issue with playing my misuc => my normal flac files are played and shown correct ( FLAC 1411kbs / 44.1 kHz) but it is not the case with my hi res files. Some of the them ( 24/96 and 24/192) are shown as flac files ( and with the correct resolution) but some of them are played and shown as WAV ( 1411 kbs / 44.1 kHz). I have changed several times the UPnP compatibility mode ( enable/disable) and everytime it is the same problem ( some hi res flac files are shown as normal WAV files).
Did somebody experince the same problem and how did you solve it ? Is they an option how to use the full functionality of the n-Stream ( with queue and playlist mode) and all my hi res files to be played and shown as they are ( flac files with the correct resulution) ?
