Mismatch Nait 5Xs and Nd5xs.
Posted by: fred40 on 05 March 2013
This worries me al lot. Someone is complaining about the harsh sound playing with a Nait X and ND5xs network player. and Harbeth speakers. According to Mr Shaw the owner and designer of these speakers this is due to the fact and I Quote"
The ND5XS network player: Minimum Load Impedance: 10kΩ Analogue Outputs: DIN and RCA, 2.1V rms at 1kHz at full level (Fixed) Output Impedance: 32Ω maximum
The NaitXS Amp: Input Sensitivity: 130mV Input Impedance: 47kΩ
This is not good. What we see is that your CD player is outputting 2100mV as its peak white loudness and ramming that into an amplifier which, according to your spec., would develop peak output from a signal of only 130mV. That means the output from the CD player when replaying musical peaks is sixteen times greater than the signal required to fully drive the amplifier flat-out across the speaker load. This is not uncommon.
The result will be chronic overload distortion through amplifier clipping which could destroy tweeters. I was working around to covering this very point in the dynamic range thread, and to answer your anticipated questions a) why do manufacturers make such a crazy mismatch between CD player output and amplifier input sensitivity and b) what does chronic clipping actually sound like so that I can identify it.
Any comments welcomed. This troubles me actually.Since I, when my ND 5xs comes in ( still waiting) will have the same combination.
Moderated Post: Fred, please ensure your posts comply with forum rules re. cross-forum discussion (which is not allowed). Thanks
