Unitiqute problem with Supernait
Posted by: Supernaim on 26 March 2013
Hi,
I wonder if anyone can help,
I use a Unitiqute as a source component in my system. Is there anyway I can prevent the Narcom 4 remote I use with the Supernait, operating the functions of the Qute such as Volume and Mute, everytime I turn the volume up on the Supernait, Qute lights up does the same.
Its a little bit annoying and it didnt do it before I did the firmware update on the Qute.
Any help would be appreciated,
Anthony
Posted on: 27 March 2013 by Gavin B
Hi Anthony
No solution - but I have the same issue with my Qute/252.
Gavin
Posted on: 27 March 2013 by Supernaim
Cheers for your response Gavin at least it's not just me with this minor annoyance
Posted on: 27 March 2013 by PinkHamster
Alternatives:
1.) contact Naim
2.) cover the Naim logo of the Qte, that's where the IR receiver sits.
3.) Get a Logitech programable remote, units can be addressed separately with one of those
Posted on: 28 March 2013 by pt109
Perhaps you can try UQ's digital output into the SN's dac ?
