Audacity recording – a few issues
Posted by: osprey on 08 April 2013
I guess this is not strictly speaking a streaming topic but I feel that yet it fits in here better than into Hi-Fi Corner (since it’s software related). I have recently finally started the long planned vinyl ripping project to back up the music and make it also portable using Audacity as recording program. Although the process itself is quite straightforward (easier actually than I expected). I have run into a couple of problems:
- I have not yet managed to find a way to adjust the recording input volume level. The input slider on the mixer toolbar has no effect on volume and neither does the operating system mixer device. Also the soundcard I am using does not seem to have any possibilities to gain adjustment. So far the problem has been too low volume (-18 dB – -12 dB). The Audacity manual suggests trying to aim for a maximum peak of around -6.0 dB. I have come around this by using the Normalize effect after the recording has been completed. However, I would like to have as pure (unedited) audio files as possible although I do not know if I could hear any difference (but it’s the principle that counts
). Can anyone think any other methods of adjusting the input volume? Or have I missed something obvious? - The recordings have been made as 24 bit/96kHz. However, when I export the recording into WAV file the result is 16 bit/96 kHz (using the other uncompressed file option in the “File Export” dialog box). Should I use another option to create a 24/96 file or is Audacity limited to 16 bit?
- After pressing "Save" in the "Export File" dialog, the Metadata Editor will appear. However, most of the information entered here is somehow lost during the process i.e. is not left when checked after the saving has been completed (e.g. album name, year and genre). Of course these can be added later but it would be nice to have the basics ready at the start. Has anyone else experienced this issue?
I hope that if some of you here have gone through this path too you could possibly give me some advice on these matters. I have read some of the other threads related to LP ripping but I have not spotted answers to these so bear with me if I am asking something which has already been answered. As always any help or comments are highly appreciated. Thanks in advance!
Equipment: NaimUniti >> Terratec DMX6Fire USB >> Laptop (Vista/SP2; Audacity 2.0.3)
