UnitiServe-SSD disc eject
Posted by: Dule on 10 April 2013
I have problem with disc eject on my UnitiServe-HD. It hapend from time to time that after ripping  CD disk don't come out from the tray. Please let me know if somebody else has the same problem.
Posted on: 10 April 2013 by GerryMcg
The Unitiserve has a manual eject option, it's accessed from the small hole on the front panel. I had this issue a couple of times. The worst one was when a light insert CD shaped had come attached to the CD, it took a few attempts to eject it. If your Unitiserve is an early version it may not have the manual ejection in which case switching the unit on/off a few times may work.
Gerry
Posted on: 10 April 2013 by Dule
Gerry,
Thank you for the info.
Dusan
Posted on: 11 April 2013 by Guiri
Mine has done that several times. Note, the manual eject isn't just a press to eject, you have to press it several times and it ratchets the disc out; I thought mine wasn´t working until I figured that out.....
