Any experiences with the upgrade of synology DSM 3.2 to 4.2 ?
Posted by: OHL67 on 15 April 2013
Hi,
does someone have any experiences with the upgrade of the synology OS from release 3.2 to 4.2 ? I run a Synology DS212 NAS server together with a Superuniti and I would like to know if there are any know issues / problems concerning the new release. It was a lot of hard work to rip all the hundreds of CDs and everything works fine at the moment, so I am really afraid to take any risks with the upgrade...
Would be great to get an independent opinion ;-)
Thanks!
Olaf
Posted on: 15 April 2013 by JohnF
I am running 4.2 -3202 on 212J without any problems using NDX and Nstream on ipad. Cheers John
Posted on: 15 April 2013 by pixies
I also upgraded to 4.2 on my Synology 212j and no problems so far.
Posted on: 15 April 2013 by Foxman50
Hi OHL
i have a Synology 212j running DSM3.2 just to let you know that transcoding hi res flacs does not work on versions above DSM3.2
If it all works fine, is there any reason to update?
Posted on: 19 April 2013 by Thorsten_L
Upgraded to DSM 4.2...everything very fine, except that the SLEEP-Mode is not working...
The disks just won´t go into deep sleep...
Any ideas ???
Posted on: 19 April 2013 by Foxman50
There was an issue with this on DSM 4.1, which was resolved with a patch. I'd have thought that this would have been fixed on DSM 4.2 have a look on Synology forum site, there is lots regarding this issue.
Hmmm... I just checked there for quite some time...
No real solution...even the patches don´t seem to work...
Shame...everything else is perfect...
