Naim Uniti2
Posted by: Uniquexme on 16 April 2013
Juz placed my order on uniti2 n ProAc Tablette Anniversary speaker. Wanna ask about the USB on uniti2 and the player layout as I wanna get my Apple lossless songs ready before my items arrive.
1. Can I plug a 2.5" HDD to the USB port?
2. How does it display song title and how do we navigate around? Does it work similar to iTunes whereby we can choose by artist or playlist? I understand that there is an app nStream for iOS. I am currently in area where I only have Edge internet connection, so lets say if I were to connect to my "3G" wifi, can I control the apps as Edge connection is really slow. The reason m asking is because if it doesn't work on slow Internet connection, I might need to get a mini toslink to digital optical cable and connect MacBook Pro. If I copy all my songs from iTunes and place them in the root of HDD, will it read them? Does it play all songs or as per folder?
Thx in advance
Posted on: 16 April 2013 by Bart
Welcome!  You have quite a bit to learn about how to use your new Uniti2, and I am wondering whether you have asked your dealer for help?  Your questions are good ones, but hopefully ones where you have resources besides this forum to help you.
Did you purchase from an authorized Naim dealer, and have you asked them to help you get your music library into a system that the Uniti2 you purchased can use it?
You will find people here quite willing to help, but you are starting from the very beginning and that is hard to do with nothing but an online forum for support.  Naim dealers know just how to help you get started
