Foobar2000 Configuration with SuperUniti
Posted by: AdamSU on 21 April 2013
Hi Everyone,
I am using Foobar2000 as a UPnP media server (installing the foo_upnp component) with my SuperUniti which works well when controlled via n-Stream on iPad/iPhone or directly from the SuperUniti remote.  However when attempting to use Foobar2000 UPnP Controller to control the SuperUniti I get patchy results.  For example I can reliably play a single track added to the UPnP Controller Playback Queue, but if I add other tracks to the queue or attempt to play a song in the middle of the queue or advance tracks Foobar2000 becomes unresponsive for 5-10 seconds and the track is not always played?
Does anyone else have experience with controlling the SuperUniti from Foobar2000?  Any advice as to any helpful Streaming Profile settings?  Naim have a setup guide for setting up Foobar2000 with a Naim DAC-V1 using the WASAPI component for bit perfect sound but for now I'd just like to be able to reliably control playback via the Foobar2000 UPnP Controller and UPnP Controller Playback Queue.
For what it is worth I have UPnP Compatibility mode turned on (in n-Stream) and am using foobar2000 v.1.2.5 and foo_upnp 0.99.45 in Win7.
Adam
Posted on: 21 April 2013 by PinkHamster
1.2.5 is a beta version as of yet. I am using foobar but not as upnp server and/or controller. So just guessing what might not be perfect.
Posted on: 24 April 2014 by thb
Hi Adam,
first time I read à post on this subject, you are still using this configuration?
Thiers
Posted on: 25 April 2014 by AdamSU
No I am no longer attempting to use Foobar to control the SuperUniti, though remain on the lookout for a reliable alternative solution to n-Stream.
