Bigh iMac question #several +1
Posted by: BigH47 on 24 April 2013
Using Bitperfect it is possible to play HD .wav files correct?
I have just run the BP test files into the DAC V-1.
OK so now I'm all set up to play HD wav files, slight problem, the only HD music files I have are .flac !
What do I need to convert them to HD .wav, to play through iTunes/BP, if indeed I can.
