192/24 files played through a 96/24 streamer?
Posted by: ChrisH on 05 May 2013
Just curious.
I have a Uniti 1 with 96/24 streaming board.
If I try to play a 192/24 file through it, what will happen?
Would it play it at 96/24, or would it not play at all?
Posted on: 05 May 2013 by Rich27
It won't play them, you will need to convert the files in order to play.
Posted on: 05 May 2013 by Simon-in-Suffolk
+1
Posted on: 05 May 2013 by ChrisH
Thanks chaps!
on the basis that I will upgrade to 192/24 sometime in the future, I guess it makes sense that if I'm going to buy any high res files, and 192/24 is also available, that I purchAse that.
I can then convert for playing now, and also have the higher res file for the future.
Not that there are too many out there that I fancy right now, but over time I'm sure it will change.
Chris I have a few 192/24 files, and really I don't hear much benefit over 96/24 if anything in terms of the original recordings and the musicality.
Given the premium usually charged for 192/24 I usually give it a miss. By all means +1 for curiosity and getting the upgrade, but I don't think you are missing much.
Simon
Cheers Simon, point noted.
