Unitiserve Problem
Posted by: floid on 24 May 2013
Can anybody help. Network will not see my Unitiserve. Every thing else on the network works ok. iPad cannot find the serve nor web browser. Serve worked fine up to last night.
Have you tried powering down the Serve then re powering?
Just touch the Naim logo on the front, it will blink then go out . Wait a while then re start by turning the main on/ off switch on the back off then on.
Has worked for me when Serve has lost contact..
Thank you for your response I have powered everything down Router the lot and now seems to be working fine. Not the first time this has happened do Naim have access to the Unitiserve through the network for some reason something strange is happening with this always seems to happen around 4am
Twice recently I have had to reboot after this 4am thing!!
Hi Floid and Richard,
This is quite strange that it is happening at this specific time for both of you. I have not had this problem but as Dis said above, when the network is stubborn, which is very rare in my case (twice in 9 months), the reboot has solved all problems. I can only imagine that it is not the unit itself but the network connection in some way.
Yes, Naim can access the unit remotely if you contact customer support.
Sorry could not help with your specific problem.
Jason.
Right I am getting to the bottom of this. Have a look at system messages. On my machine it says at 04.45 24.05.2013 engineer upgrading. What's all that about and upgrading to what.
It is the daily or nightly backup job, but why this should create a network problem I do not know. Naim can checkout what is going on if you email support.
