Adding BBC radio streaming shows
Posted by: Becks on 25 May 2013
Hello,
Just bought myself a Uniti Lite, and really liking it so far.
Using the iRadio function on my Unitilite,
For most BBC radio stations, I can find the past week shows which are available for streaming on their website (for instance, Jarvis Cocker on radio 6).
However, not all past week shows are available on the iRadio section - for instance, I can't find Gilles Peterson on Radio 6 past week show.
Any idea how can I add these missing shows to my radio station listings?
Posted on: 14 July 2013 by Becks
Bumping this post, help anyone?
Posted on: 15 July 2013 by Gavin B
If you can find other R6 shows, then this might suggest that the BBC haven't put the GP show up.  Can you find it on iPlayer?
Posted on: 20 July 2013 by Becks
Thanks for the reply,
it is available on the iPlayer, but not on the naim iRadio listings.
