Unitiqute upgrade
Posted by: w33logic on 04 June 2013
Now that the Unitiqute 2 has been announced/released, is there any information on the possibility of having a UQ1 upgraded to the same spec? I know that Naim are pretty good at the firmware updates, but I'm not so sure about hardware.
I posed this question to Naim and their answer was that there is no way to upgrade a Qute v1 to v2. The Qute v1 is at the end of its road.
I was a little surprised and disappointed. It would have been nice if there was someway, sort of like a throwback to the NAC 32 upgrading to the 32.5.
By the sound of it you'd have to replace almost the entire innards for an upgrade to V2. Probably not a realistic proposal in terms of time and cost.
With the regularity of new model introductions in the Uniti range, though, it seems the brand's legendary S/H values are likely to take a knock.
Frustrating. Will Naim continue to support the v1 with firmware updates?
Yes ... the V1 and V2 units run the same firmware so will remain current.
To upgrade a V1 unit to V2 spec *WOULD* require a complete new main board *AND* a new chassis so isn't really economically viable to do...
Phil
You can always just add a NAP100 and turn off the speaker output on the Qute. Huge gains there.
I have seen the NAP100 / Qute combination mentioned around the forums but it is not mentioned anywhere in the 'official' Naim documents (the NAP100 is only ever mentioned paired with the DAC-V1 and there are no upgrades mentioned for Qute other than power line or DAC). Is this an officially sanctioned / recommended combination?
In the past we ran our UnitiQute as a source (DAC/Tuner first, streamer later when we got our NAS to work) via a 52/SC and also as a pre-amp via a NAP140 IIRC. As a source I prefer the Qute to the ND5SX, which we bought and soon replaced with an NDS. The NAP140 combo with Qute as pre-amp/source was also good, but we prefer the amp in the Qute in its current role as Kitchen Radio/System.
I'm not surprised that there is an absence of information on officially sanctioned / recommended combinations. The flexibility of the 'Qute would make such recommendations very, very broad indeed.
The Qute/NAP100 works easily, the NAP100 has both 4-pin and RCA inputs (not to be used at the same time) and the Qute has Pre-outs via RCA. Works best if you disable the speaker output on the Qute.
The combination of Qute / NAP100 works very well ... we don't specifically plug the NAP100 as an upgrade for the Qute as the Uniti products are intended as "All in One" boxes and adding a power amplifier of any kind to a Uniti, UnitiQute or UnitiLite then makes it no longer an all in one solution.
A number of users have been running Qutes into NAP250s (albeit not an ideally balanced system) quite successfully so there would be no issues with a NAP100 and I have been running exactly that setup myself since last October with very good results.
Phil
I also use Qute2/100 combination, possibly the best value system available.
Awesome.
