Ethernet cables
Posted by: Sdan on 12 June 2013
I am purchasing a UnityServe. My router/internet (wall) outlet are 25 feet from where the US will be shelved. Will the sound degrade terribly running a 25' ethernet cable? Someone suggest hooking the US into a Apple AirPort Extreme. This would still requires running the 25' cable from the AirPOrt Extreme to the router.
Suggestions?
Tim
Posted on: 12 June 2013 by Simon-in-Suffolk
No, should make no difference at all, it should work well. Regular electrical 100Mbps Ethernet works at least upto 100m.
Simon
Posted on: 12 June 2013 by RaceTripper
I have a 100' CAT6 cable from my router to my ND5 XS. The sound quality is just fine, all the way up to 24/192 audio.
Posted on: 13 June 2013 by Harry
It will make no difference. This is what Cat cable is supposed to do.
Posted on: 13 June 2013 by Iver van de Zand
no will not make a difference. Ensure you work with Ethernet cable Cat 5e of higher
Posted on: 13 June 2013 by ragman
As all others told you: No difference.
The protocoll is in each case the same and each one will perform good enough in your use case.
Posted on: 13 June 2013 by Geofiz
Would suggest exercising some care in how you route your 25' run of ethrnet cable.  Past experience setitng up several computer networks suggests avoiding where possible running the cable in close proximity (within 1 or 2 inches) of any major electrical wiring conduits.
