Anyone Use JPlay?
Posted by: Hot Rats on 13 June 2013
I wondered if anyone with a computer front end had tried out JPlay:
I use a PC laptop with Windows 8 (x64), JRiver Media Center 18, M2Tech HiFace Evo with Paul Hynes SR1 Power Supply into Naim Audio DAC/Naim Audio XPS. I found that JPlay considerable improved the sound although JRiver claim that JPlay is a 'hoax'.
I would be interested to know the experiences of Naim owners using JPlay
I use only JPlay, on a dual PC setup. Both PC's are purpose built and dedicated to audio playback as Controler and AudioPC.
My AudioPC runs on a tweaked Windows 2012 Server Core edition. My audioPC on Windows 8.
I run it into via a Diverter HR2 into Naim's DAC/XPS-2.
Using Jplay with its Mini-player is easily superior to any other software player, be it JRiver, or foobar or whatever. I have tried many on Windows OS.
The sound quality of JPlay is the best I ever heared. The use of the tweaked Windows 2012 Server Core edition as operating system on the AudioPC is another HUGE improvement to a consumer Windows 8 or 7 OS, even when using Jplay.
I think the developers work magic with PC audio playback.
Aleg
I'd be interested to know in what way the Windows 2012 Server Core is "tweaked" . Any explanation why the Windows 2012 Server Core is beneficial to SQ?
Is my understanding correct that the "AudioPC" is for storage and serving and JPlay is installed on the Windows 8 Controlling PC? Is a NAS involved in your setup?
Thanks in advance.
PureReader
when using JPlay in DualPC setup, JPlay is installed on two PC's.
The ControlPC is used for playback and streams the audio signal to the AudioPC. Music is stored on the ControlPC or the ControlPC is attached to a NAS, as I have.
JPlay on the ControlPC is implemented as an ASIO-standard driver and is used from an ASIO-capable software audioplayer. I use JPlay's own JPlayMini, but you can use it as a kind of plugin from JRiver or foobar or other ASIO-playback capable software player, just point it to the JPlay ASIO-driver.
I experienced some issues using JRiver Media Center 18/JPlay/JRemote. I was experiencing interrupted playback and laptop hanging although this was mostly when playing high resolution files, particularly DSD files that JRMC was converting on the fly with its internal engine. I could also not use the ULTRAstream engine in JPlay with any stability. My laptop was an Asus with Intel P4400 2.3GHz processor and 4GB RAM.
I have since upgraded my laptop to an Acer with Intel i5 processor and 8GB RAM. This has solved all of the issues. So I guess the caveat with JPlay is that it sounds great with JRMC but to give of its best, it needs a powerful laptop.
