Dear all
I've been asked to do a job for someone which involves running five different Twitter feeds. There would be a certain amount of overlap, but each feed would also require its own content.
Rather than logging in and out of each feed every time, does anyone know of a decent piece of software or an app that would allow me to manage all the feeds on one place, either separately or together as appropriate?
I have a Mac running Snow Leopard and an iPhone 4 with iOS 6 on it, if that's relevant.
Thanks!
Posted on: 13 June 2013 by osprey
You could try if TweetDeck had features which could help you in your task. I have not tried it myself but I have heard that some heavy users have found it handy. From the web: "TweetDeck gives the Twitter experience more flexibility and allows advanced users to gain valuable insight to what's happening at this very moment on Twitter. TweetDeck is currently available as a desktop app, a web app, or a Chrome app, and can be downloaded at tweetdeck.com."
Posted on: 13 June 2013 by Kevin-W
Thanks Osprey, will give it a go.
