"Tracks not located on server" problem
Posted by: ken c on 16 June 2013
Hi Guys,
how does one get around the following problem:
I have a playlist and when I open it, some tracks are marked with an 'x' on the right hand side on my iPad running nStream in a uServeSSD/NDS config, both hardwired into the router.
The specific error message when I select a track for playing is:
"This track cannot be located on the server. Do you wish to remove
just this track
all missing tracks
cancel
I want to do neither of the above. I want to play the track that is what I put it in a playlist!
Any hints gratefully received.
Many thanks
enjoy
ken
Posted on: 16 June 2013 by Cbr600
Ken,
    Are the tracks on the SSD?
Can you select the tracks individually from the album list?
If yes, might be that you just need to power down and up again, and the playlists would be re established.
Posted on: 16 June 2013 by ken c
Originally Posted by Cbr600:
Ken,
thanks. but power 'what' down? the U/S, I guess?
but why does this issue arise? number of playlists above a certain limit?? or what?
enjoy
ken
any more thoughts/suggestions?
I have power-cycled the U/S and to no avail.
enjoy
Posted on: 16 June 2013 by Paul Quigley ie
Power off and on your iPad.  This has fixed it for me!
thanks Paul. done that as well, no dice... :-(
enjoy
ken
Posted on: 17 June 2013 by Claus-Thoegersen
Do you have the same issues if you use the dtc?
Posted on: 17 June 2013 by ken c
I will check. dtc is only used for maintenance with NDS/UServe setup. so I am not sure whether this issue will show up in the dtc, but I have a look anyhow..
enjoy
ken
just checked. unfortunately, playlists created on the iPad with n-Stream are not visible in the dtc.
thanks for suggestion.
enjoy
ken
Posted on: 17 June 2013 by Cbr600
Ken,
   As per my previous query, can you select individual tracks from album heading and play them ( i mean the same track as on the playlist).
If so it would suggest that the playlist has got corrupted and need to add track again and delete previous one with x against it.
If unable to access individual track as above, would suggest some tracks have been re catalogued by the u/s.
