Metadatics and XLD
Posted by: EJS on 19 June 2013
Hello all, I have an issue with file conversion on mac, and was wondering if anybody on this forum knows what's going on. The issue: I rip via iTunes into AIFF, and use Metadatics from the app store to edit metadata of my AIFF files. That works fine. However, I notice that if I try to convert my AIFF files to WAV (or any other format) using XLD, XLD does not pick up any of the metadata. If I use XLD directly on the iTunes AIFF file, all seems fine with the embedded metadata. Apparently, metadatics does something that is not compatible with XLD, and the issue is either with iTunes, metadatics or XLD, or any combination of these.
Does anybody know of another AIFF - WAV file conversion program on mac? I'm reluctant to buy blind from the appstore...
