Finally Active Ovator 800
Posted by: Patrik on 07 July 2013
Finally recived my active Ovator 800. In summary :-)))
The Ovator 800 has a very clever packing (more on that later). There are reusable plastic locks to open the box and there was a ramp included to roll of the loudspeakers from the pallet. Thanks to the ramp and wheels it was an easy installation.
The problem with the clever package is if people who are not interested opens it, like the customs, they will probably trash the package. Of course on box was damaged by the customs during there inspection. When you have waited over six months for the Ovator 800, I can promise you that you're heart rushes before you can check the loudspeakers. Apart from a lot of fingerprints they were Ok. I think that Naim need to have clearer instructions on the outside of the box for when "dummies" open it and have to close it again.
Ovator 800 is huge loudspeaker. They will dominate most rooms and its the price you almost always have to pay to get to this level of performance. After some initial listening the Ovator 800 were placed 75cm from back wall and 53cm from sidewalls. (Measured from edge of loudspeaker box. This will be revisited once they have been properly run in). A minor point is that the volume knob needs to be turned slightly higher to get same sound pressure as with active Ovator 600. I payed extra to have them in high gloss black with some silver sparkle. They look beautifully and are finished to a very high standard.
Now to the important part. How do they sound? They are just a week old so its still early impressions... I once had active Linn Kan which sounded amazingly fast. Some of that speed was due to missing bass performance and to be honest a lot of other things was also missing. But they could play music. I also have had active DBL and the bass was amazing and they really could play music. You could also have amazing parties. When I moved to active Ovator 600 it was a very balanced system and the best system I ever heard judged on PRaT. But I missed the bass from the DBL, although everything else was better. The Ovator 800 are everything above: super fast, amazing bass, loads of PRaT, and of top of that they can play "HiFi". Yes, they can party as well. The Ovator 800 is so balanced! When you close your eyes the system disappears and its all about the music.
I don't miss anything, for now ;-)
Patrik
